forecast »
https://forums.nicoclub.com/forecast-u7026.html
Mon Jun 30, 2003 7:47 am
What you're not seeing with the idle timing is what happens at cruise or under load.
On no car is timing static, obviously with new ECU driven timing have large 3 or 4D maps (engine speed, throttle position, gear selected, engine temp, airflow) the timing will be all over the place.
On very primative systems the engine vacum controlled timing - vacum advance.
On 70's cars a hybrid of electronic ignition was used, no lookup tables but a bit better than vacum accuated coil.
On these cars, the idle timing was partly determined by where the timing needed to be at 70 MPH, not what made for the best idle. (A friend used to time his 50's car by checking the top speed possible at different settings)
The speed of a burn is not function of spark timing, but chamber geometry, compression ratio, fuel properties, fuel atomization, and distribustion of fuel droplets.
with ECU driven timing, the idle timing is whatever happens to be best for emissions and smooth idle. On some cars, which use a "timing adjustment connector" the adjustment of the CAS with an timing light is only to calibrate the CAS so the ECU knows the exact position of the pistons.
with ECU's and wildly different chamber designs you're not really comparing apples to apples in looking at different idle timings.
So in VA cars need to be leak-free to pass safety? Is this an annual check, or just done when cars pass ownership?
The only thing more mind-boggling than how much some people spend on cars, is how much some people won't.
