if you turbo os supercharger do you have to retime car
casper82
Car: 91 240SX
after S/C my ka-e it seems like it out of time now do i have to retime it ? thank you
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
look for your answer in the KA-T section.
ZOMG.SR20
Car: 1990 s13
but he's supercharged...... It could be different from turboing
1 step colder plugs?Tuned?advance the timing alittle
just some ideas
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
ZOMG.SR20 wrote:but he's supercharged...... It could be different from turboing
just some ideas
**facepalm**
just advance the timing as far as it will go and turn the boost up
Tsukiko
Car: 1990 240sx fastback KA24E
if anything you want to retard timing to keep from detonating
hpmachine
Car: '05 EVO8 + '95 240sx
This thread has the potential to be epic
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
Koshin wrote:just advance the timing as far as it will go and turn the boost up
I second this notion.
awretham
Car: Nissan 200SX S13
The mechanical timing won't have changed, nor should the ignition timing unless it was manually adjusted, has the car been mapped to suit the s/c setup?
ghx407
Car: 1993 240SX KA-T
If possible get an ECU tune or an MSD BTM and set base ignition timing to stock.
If you can't get either, at least retard base timing about 1/2 deg. for every psi of boost over 4 and keep max boost under 8-9 psi.
Always use the FSM procedure to adjust ignition timing.
ZOMG.SR20
Car: 1990 s13
Tsukiko wrote:if anything you want to retard timing to keep from detonating
I thought of that later on
:facepalm
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
take it to a reputable tuner.
casper82
Car: 91 240SX
ok, thanks, its getting 5 psi on a 3 inch pulley and i have been playing with it today and got it to run a lot better but not right yet
i tried to get a video of it running but it was to bumpy and it started to rain so i had to stop for the day..oh and i really need to get to a exhaust shop fast
http://www.youtube.com/watch?v=4D3iwStv72U
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
2000 RPM's take off?
You must hate your clutch :P
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
hpmachine
It's a rat rod!
awretham
Do I spy a DV... You need to ditch that for a start.
