I would agree with that but then you could ask GarrettCarl H wrote:ive done the math and for a low boost setup (14psi) my choice would be the hks t51r or the garret equivalent the 'small' gt42.
Where did you get your turbo if you don't mind me asking?qsiguy wrote:I'm really happy with my Master Power T70 w/ .68 turbine A/R.
http://www.partsexpressonline.com/wrxratd wrote:Where did you get your turbo if you don't mind me asking?
Sorry carl, but the bullseye turbos are bits and pieces of borg warner stuff with some custom housingsCarl H wrote:bullseye turbos are bits and pieces of garrett stuff.if i had coin i'd go with the borg warner extended tip turbos...thats me tho.
the pt71 is not aka gt42r, not even closegs14racer wrote:One of my friends is gonna loan me a t67 and ive decided im gonna get a pt 71 aka gt42r after im done testing.
I agree, for the money this is a great turbo for a fairly wide range of applications. Are there better fits out there... probably... but for the price a MPT T70 is dang hard to beat.qsiguy wrote:I'm really happy with my Master Power T70 w/ .68 turbine A/R. I would like to try a smaller A/R for my rear mount to compare but I'm in boost pretty quickly as is. If you used this same turbo up front I'm sure it would be awesome. It's capable of much more boost than I can currently use with my stock MAF and injectors.
Thanks for sharing that info and please post back with how the turbo performs on a VH45. How much are the HX55's brand new?vqpwrd240 wrote:I talked to a Holset dealer that works with turboing Mustangs today. He said something along the lines that the HX55's come with specific exhaust housing that cannot be changed. I let him know about the 22cm^2 housing on mine and he said that a 22cm^2 on the HX55 is right at a 1.0 a/r. The 4.6L Mustangs are seeing 5 to 10 psi with .8 and .9 a/r between the 2500 and 3000 rpm range. He did say there may be a little lag but you could still get good usable power at 3500/4000 and on. He said to go ahead and use it for the power I want to make. Thanks again.
Ferhan
