I'm with you on what you're thinking, but to be realistic, that would require a much larger engine or a turbo. I think I would have suggested maybe sacrificing some of the high rev ability to tune for a bit more lower end torque.TESLAASTRO wrote:300 lbs less and 400 hp.....
400hp will be needed to compete with the Camaro/Charger/etc that will be released next year.TESLAASTRO wrote:300 lbs less and 400 hp.....
Well I don't mind the current HP, dropping the weight of course would make it significantly fasterTESLAASTRO wrote:300 lbs less and 400 hp.....
I don't think the color selection falls on the engineers, but I could be wrong!rn79870 wrote:What would you suggest in the way of changes or additions to your G37.
I'd like to see more colors. There seem to be too many colors in the silver to gray range. Not that they are bad, but an off- red metallic paint on a G37 would be a heart stopper. Even a jade green metallic would be pretty. And, factory chrome wheels, with a nice unique to the G37 19" 5 spoke design.
Add your comments to this and maybe, who knows, Infiniti might stop by and read it.
smark wrote:The windshield wiper switch is a poor desgin because to wipe once requires the control to be moved back and forth from the current setting.
For example, if it's set on a long delay wipe it has to moved up to wipe once setting and then back to the delay setting. In my Lexus Coupe the control lever is pulled once for each wipe or held for the desired number of wipes.
To spray and wipe the windshield, a button in the end of the Lexus lever is pushed without changing the wipe setting.
It has plenty of HP... it badly needs ft/lb's though... another 40-50 at least.TESLAASTRO wrote:300 lbs less and 400 hp.....
