I found my problem tonight with the dome light staying on and such.
If you remove the passenger trim above the door on the inside of the car. Its the plastic molding that the sunvisor practically touches. You will have to take off the 2 screws for the visor, and remove that, then pull/pry off the sunroff molding if you have one, and take off the molding behind that also by removing the 1 screw and pop off the front of that molding so you can remove the first molding i mentioned because it sits overlapping it. now you can pry down the roof trim and if you look towards the column that divides the window and that triangular glass in the back that says 240, underneath the roof pannel, you will se 2 wires taped around pretty crappy, and you will see a mount bracket for the auto seatbealts that has a sharp edge, now the wire is pressed up against that bracket im almost 100 percent sure!!! just tape it up where its rubbing real good so it doesnt happen again.
seems to me like they should have run the wire "behind" the mount for that assembly, but this should be it, unless you have a bad door switch.
-Chris K.240s maniac
