Rex »
https://forums.nicoclub.com/rex-u6324.html
Tue Feb 21, 2006 5:47 pm
My point is tirerack lists a 10" wide wheel/tire combo as fitting, versus being made to fit. Maybe a subtle difference, but as you've noticed on NICO what "fits" is much more accepted than what "can be made to fit".
Now for "understeer", as you may know, it's the condition where the front tires reach there "break loose point" before the rear tires, causing the front end to push, creating a larger turning radius than necessary to complete a maneuver. The concept is larger than necessary (for engine power/traction) tires on the rear will mainatain traction beyond the point a loaded (weight shift during cornering) narrower front tire can. The result of the front tire "sliding" is understeer. Note that this sliding can be so lsight as to not be readily noticeable, yet still requiring a larger radius turn than would be necessary at a lower speed or with better matched tires (size, adhesion, etc).
I don't drive my car in a manner that this would be an issue for me, but there's always the possibility that some idiot will make it necessary for me to make an evasive maneuver .
