if pistons or valves need replacing will car still start???
vacnsewmedic
Car: nissan
Im just wandering because im trying everything I can to set timing and car will not start, I had it started once and it was rough
TheOne
Car: 93 240sx FB
the car wont start if you have no compression(when valves are broken, which can't close).
but it depends, there's a lot of things that can make a car not start.
tho it could have been the valves since ya say it once started rough.
vacnsewmedic
Car: nissan
should i just take the car to a mechanic, or how can i see if the valves are broken
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
What led you to this position? Did you replace your timing chain and now it wont start? Or did you just come out one morning and it wouldnt start? Or did it die on you in traffic? Some more info would help.
Check obvious things like spark & fuel. Test your compression (if you can). Try cranking it with the radiator cap off (blown head gasket test). Look at the condition of your oil (milk chocolate consistacy also means blown head gasket). We need more info in order to better help you.
vacnsewmedic
Car: nissan
Well it started tapping really loud, later I found out the timing chain was about to break off, but I bought new chain kit and re-installed it, when I crank i here this slow winding noise, I keep trying different timing positions from ppl but doesnt still seem to crank. If u can guide me through some I would really think your COOL...lol
but for-real i am almost over this, I dont want to throw the car in the trash
Im getting a new starter put in as we speak, i blew that trying to crank it so many times
and i will check some of those ideas u said above....thanks
TheOne
Car: 93 240sx FB
test the compression, that way you'll know if the valves are bent/broken.
vacnsewmedic
Car: nissan
hey no compression in 1 & 2 145-150 in 3 & 4 ?????
What might be the case
JNM240
Causes might be stuck/broken valve or blown piston ring. Put a tablespoon of oil in each of the no compression cylinders and immediately check compression again. If it goes up, rings. If not, valve. Another possibility might even be blown head gasket (between cylinder 1 & 2). To check for this, take radiator cap off and crank engine. If coolant shoots out, blown head gasket. Also check condition of engine oil. Chocolate milk, blown head gasket.
vacnsewmedic
Car: nissan
oil is beautiful,,,thank god,,,,no coolant shooting out..either...
i havent tried the oil trick yet, but will after i get my store opened up and running.......thanks alot
if valves or pistons,,,,,is it an expensive repair
where is a good place to get them thats not to expensivei heard of http://www.autopartsgiant.com (dont really know)
ohhh...Is it something that someone with some alright skills could handle?
JNM240
Before you go jumping to conclusions, lets first find out WHY you have no compression in 1 & 2. Largely because, replacing pistons is an engine rebuild. No way around it. So lets see if some other things are at fault.....
Has you car started at all since you put the timing chain on?When you were doing the timing chain, did you make absolutely certain that everything lined up correctly? (camshaft, crankshaft, oil pump, distributor)
boostme
Have a leakdown test done by the place thats doing your starter and ask them to find out where you're losing compression. That will determine the cause of the problem and you can go from there. You possibly could have misaligned the cams but I personally think you have bent valves. I believe the KADE is an interference motor.
I'd pay to have the job done if I were you. If you're dead set on doing the work yourself and aren't super technical I'd look for a new motor to just swap in. Doing a head is pretty technical work for a non professional and there are plenty of pitfalls along the way where you can get caught up *like you are now*.
