ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Fri Jun 24, 2011 1:21 pm
The power steering fluid, rad and coolant fluid, the diffs, automatic and manual transmission, 2 speed transfer case...all are good habits to get into for routine changes.
Radiator should use long life 5 year and be tested each year and look inside the rad for plaque build up at the fins, if none, good but if there clean and change. The rad needs to be washed externally, very carefully and inspected.
As does the main cooling fan, cleaned and examined, is the clutch system OK.
The belts other than timing belt will show evidence of wear and that wear will last a long time, if neglected. Twist the belt in your hand, can you see cracks, worn edges? How does it feel
A timing belt if you have one on an interference engine is critical to change by time and distance because these belts wear and THERE IS NO INDICATION THAT IT IS BREAKING. These interference engines will self destruct depending on speed at time of belt breakage and the cost of a timing belt and installation is cheap compared to a new or rebuilt engine.
Rubber deteriorates, so do ignition HT ignition cables, keep them clean by wiping with a soft cloth and use nothing, no sprays, no solvents, nothing, no insulators. Sprays have a tendency to stick, work into the material and over time with humidity and dirty engine air make a muck that is highly conductive on a wire that must be highly insulative.
An over looked problem is the distributor, internally and externally. It must be cleaned, air blown every other year and a lot of ignition problems will go away.
