I know it might sound dumb but where is the TPMS sensor?? I never took the wheels off. btw thanx for your input.lawman12 wrote:I have had my OEM TPMS sensors in three different wheel sets and they always matched up to the M. No problems at all. I have read where other owners who switched wheels have had problems with the TPMS sensors reading after the swap.
If you don't use your original TPMS sensors you will probably need a match from the dealer. If you use your original 18s, they should match up.
You can use the same lugs if staying OEM.
TPMS = tire pressure monitor system (or somthing like that) the TPMS is the device that measures your tire air pressue and sends it to your computer, so when you check your tire pressure in your Ms system it is the TPMS in the wheels (1 in each wheel) that sends the info.woo wrote:
