The rear calipers are exactly the same, so that wouldn't make any sense. On the front, if the s14 is like the s13 (not sure and can't seem to find any info), then the abs model has slightly larger rotors and different calipers (2mm wider and 5mm greater diameter). I'm not 100% sure, but I think all 5-lug model s14's had ABS so that would mean if you wanted stock calipers & 5-lug on a s13, you'd have to either have abs calipers (from a s13 or s14 assuming they follow the same pattern the other calipers do) or redrill your 4-lug rotors.
Do any of you s14 owners out there have a FSM? We can use some specs on the brakes please!
