Mike,
I think mchedaddi has a good point! That cd may work, but i believe there are frqencies that you can download off the net for free.. these are often used my audio tuners to tune/test an audio system... I will look for one and get back to you!
now, what i would do first and foremost is check the foloowing three places
1. remove your a pillars and listen to music and drive around... see if the rattles are still there. There are these white pieces that are attached to the car frame under the A pillars, and they rattle in my car, and I will be eliminating tose when I finish my custom a pillar setup
2. if the rattle continue with the a pillars off, next, remove the speaker covers for your 3.5" dash speakers. At certain frequencies, they may rattle also. At this time, be sure to check the 3.5" speakers themselves. Sometimes, they can rattle loose and the screws could be rattling when the get certain frequencies through the car's vibration or stereo noise.
3. Check the covers for the side view mirrors. they look like triangles. I know these are rattling in my car and i have to fis these.
in any case, these are the three most likely candidates for rattles up front. if you fiond rattles in either of these three then
1. for the A pillars, disconnect the white pieces and wrap some cloth or carpet around them behind the a pillars. That's what i'm gonna do!
2. A. for the speaker grills , a thin layer of electrical tape or a thin layer of insulation where the grill contacts the dash should elilminate that. B. for the speakers, just tighten the hell out of em!
3. if its the triangle piece, use some non hardening putty around where the insert into the door (you'll see what I mean when you take em off, and yes you must remove the door panel to take em off completely), and for the rest, then insulation tape or that trunk carpeting material (that they cover wsubwoofer boxes with) should work behind the actual triangle piece!
i know this was long, but doing these one at a time should eliminate the rattles! Hope this helps!
your speaker grills for your 3.5 inch speakers
mpbclutch33 wrote:Right...... All comments that I expected to hear and yet no useful information.
