If going to rebuild engine should I replace piston rods?
Kundo240
Car: nissan 240sx 1990
I am going to rebuild my engine but nobody can seem to answer me if I can keep the same rods or replace them, I am going to turbo it in about a year after the rebuild so that is why I want to find out. can anybody help?
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
If you are rebuilding the engine, I would go with everything as new as possible. KA's have a strong bottom end (they have held up to 400hp) but since you are considering turbo, get new, stronger connecting rods just to be safe.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Stock rods have done +500rwhp...so unless you're shooting for more, have yours magnafluxed (checked for cracks) and re-use them.
- Brian
Kundo240
thanks alot, appreciate the info... to get my rods magnafluxed would I have to just go to a machine shop and get that checked? or is there some where else?
2Fass240us
Car: 93 240SX SE w/redtop
Take them to a local engine builder.
I agree on having them checked and reusing them if you can. I reused my stock SR rods, as they've been proven to reliably handle over 350rwhp. Good luck.
-Andy
