idling too high
phanatikz32
Car: 1991 NA to TT z32 biatch!
for some reason my z just started idling at around 1200 rpms in the morn. and after i drive it around a bit it drops down to about 1000, does anyone know what is going on?
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Like with a lot of litte annoyances on the Z32.....its most likely a vacuum leak.
phanatikz32
what does that mean? is it expensive to fix?
nsrZ32
78 Datsun 280Z
01 Ford Focus S2
Nah, its cheap and easy to fix. Just do a test on it and find where the vacuum leak is. If that's the cause its going to be one of the rubber vacuum lines under the hood. You can buy universal hose at any parts store
phanatikz32
sorry but can you explain it in more detail? how do i test it, what kind of tube am i looking for? also would i feel a difference in accelertion due to this prob.? recently ive been feeling unusuall lag in 1st gear, and my car seems to be running kind of rough, do you think there could be a link between these 2 probs?
300zx_tt
Car: 300zx twin turbo
where are the vacuum lines located and what do they carry becuase my z started idling high lately its been doing around 1,500 at start and after aobut 10 min it would keep dropping slowly to around 700 and just stay there but today i ran the car and it idled at exaclty 1,000RPM. After about 10 min it would drop to around 700rpm and for 10 min it would stay and again go back up to 1,000. my oil is very dark, i will change it on monday and my turbos are leaking, they are barely leaking but i know im burning oil hence the white smoke so i thought it owuld have somehitng to do with that, but all the hoses i have are old and ive had about 5 leaks in the 5 or so months i own the car, they were simple fixes took about 2 hours to change one that was next to the turbo.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
vacume lines are generally the small hoses running to various places from your intake manifold and or piping, they carry nothing, they just allow the suction of the engine to be used to trigger other devices or meters, look at the ends where they connect to their boars at either end if they are hard and cracked replace them, any parts store sells the tubing by the foot in various diameters, just take them a sample of the size you need and tell them how long
