Is the A/C on by any chance? The A/C compressor kicking on makes a "pop" noise on every car I've owned...usually only noticeable at low speeds or while idling like you describe. Turn off the A/C and see if it still happens.DrivingHabit wrote: When car idles at lets say drive thru fast food, my versa makes a popping noise coming the engine is this normal??? could it be the engine fan or the timing belt??
