DirkLance »
https://forums.nicoclub.com/dirklance-u31378.html
Fri Jan 27, 2006 9:30 am
Ok my problem is 3 fold.
First off, after warming up the car for 10 minutes in the morning or whenever I get a good idle of around 900-1k rpm. After normal drive, maybe light boosting, FWY driving whatever, it will sometimes stick at around 1200-1400 rpm. When I park the car I let it idle some more (no turbo timer), and it doesn't go down. Sometimes it will even go up a click or two.
Second, while driving and slowing down down to a stop, if I take the car out of gear anywhere above ~1500rpms, rpms drop down to 2-300rpm, will catch for a moment, drop, and then the car stalls out. If I keep the car in gear till I reach a idle rpm's, then take it out nothing happens.
Finally, the other day while I was letting the car idle in my parking garage, I popped open the hood and the car starting to slowly lower it's idle until it stalled out! It happened a second time in a different place under different circumstances but as soon as I closed the hood, RPM's came back up to the normal range.
This is in a stock S13 blacktop with on an RS*R ExMag exhaust. Also there is no intake filter currently on the car. Please help me out no this! Thank you so much NICOnauts!
