adrianfromthecastle »
https://forums.nicoclub.com/adrianfromthecastle-u30128.html
Tue Feb 27, 2007 7:51 am
have you tried cleaning your maf? its a simple procedure and not as tough as taking the iacv out.
go to your parts store and pick up a maf cleaner, not the carb cleaner, theyre 2 different chemicals. the carb cleaner will ruin your maf if you use it.
unplug your maf pigtail and take your maf out completely from your engine. then take a screw driver and unscrew the top 2 screws taking it fully apart. lay it down and spray that ma'fugger with the spray a few times till you think you've gotten everything. allow time for it to dry, then plug it back in, and start it back up.
hopefully that will work, if not, then i'm pretty sure its your iacv, tps, and/ or vacuum leak.
but at least this way you know for sure its not your maf
