fastboatman29212 »
https://forums.nicoclub.com/fastboatman29212-u165024.html
Wed Jan 05, 2011 6:44 am
My truck has the same issue with idling. Most of the time it idles high, usually when the engine is warm. It usually idles about normal when it's cold, but it can change almost anytime it wants to. I know it's not a vacuum leak, (new vacuum lines and tested with carb cleaner same as you did). I've been blaming the carb itself because the choke flap stays all the way open ALL the time. I inspected and found a broken linkage between it and the ????? (I don't know the name of it but it's on the back DS corner of the carb). I bought another carb at the salvage yard hoping to use it for parts or as a replacement but I haven't done anything with it yet. I will post photos of what I'm talking about later. (In fact, I plan to post detailed photos of every part of the carb for future reference. That way people on this forum can communicate more clearly about carb parts when they have problems).
If I find a solution for the fast idle problem, I'll be sure to post it and let you know. For now, I just keep running the same carb because I get 22 mpg like it is.
