Idling Issues/No Throttle Response/Stalling While Driving
Xemplifi
Car: 90 300zx TT
Alright so first off, I have a 1990 Z32 TT. No modifications have been done to the vehicle (yet) and I've already hit a problem. The vehicle is idling really rough and usually just bogs down and dies. My oil pressure I've noticed drops to about 20 or less psi when I let off the throttle and seems to only get up to about 55 psi when driving. Today while I was driving, the vehicle stalled at about 15-20mph. The vehicle was at operating temperature when this happened. And also, on some occasions the vehicle doesn't want to go even if I have my foot on the gas and then randomly regains power. If anyone can help me out it would be greatly appreciated. I have a video here of the idling issue if anyone care to watch it. https://youtu.be/rFf44UaJYGI
z.Leinbach
Car: 1990 Nissan 300ZX NA T-top
I'd check all your air hose clamps, then check the timing should be 16°beforr top dead, and make sure the idle air is adjusted right, then test the coils make sure they are firing right. Then replace fuel filter an pcvs, the little things can cause big problems
RubyRed300ZX
Car: 1993 300zx Convertible
15 Degrees
Xemplifi
Car: 90 300zx TT
Timing is adjusted by how the crank angle sensor is turned, right?
z.Leinbach
15 thank you. Lol. The one that's on the driver side bank that's protruding out of the timing cover yes
Xemplifi
Car: 90 300zx TT
Ok, so I tried removing that yesterday because I was gonna do some test on it with my multimeter. But I just have to remove the 3 bolts and unclip the wires to the sensor right? Cause It wasn't budging haha
