lego126 »
https://forums.nicoclub.com/lego126-u171829.html
Mon Aug 29, 2011 3:38 pm
I have a 97' nissan HB 4x4. I had my timing guides break,and a hole was eat into the timing chain cover, rebuilt the engine, and JB welded the little hole. Ran perfect for 5 months, then I noticed I was a little low on Antifreeze, checked my oil and had a hint of AF in it. So I torn down the front of the engine, this time I took it to have the cover heliarc welded. , long story short I ended up having to remove the timing chaing and reinstall it, and put it all back togather. For the last few weeks,(since I got it back togather) I'm idling a lil' high. and I have kinda sluggish pickup. I'm currently at around --10BTDC. I've played around a bit and if I Advance the timing a lil, it idles around 1200 RPM, but the pickup is better, and If I retard it, idle is closer to normal, but it's like falling on it's face. I'm hoping I'm not a tooth off in relation to my cam/crank. A friend of mine has told me he things I would be missing or something alot worse if I were a tooth off. any help would be great. Thanks.
