rexhunta »
https://forums.nicoclub.com/rexhunta-u25385.html
Tue Dec 06, 2005 2:48 am
K guys, your the best, so i need to sap more energy from your brains..
My Idle in the last 2-3 days has gone real weird.. it's going from 700rpm to 500rpm every like 3-4 seconds ( without climate control turned on), and on the idle, it's making popping noises every couple of seconds.. I've tried different plugs, different plug gaps from 0.7 mm to 0.5mm, tried champion gold plugs, ngk double platinum, and normal budget NGKs, they all do it.. i've checked hoses, timing is at 15btdc, everything !! lol
Worse thing is, i have a track day this sunday, I'm gunna run some Octane booster ( car pings when it gets hot here atm, tried timing, but just toooooo laggy), and i don't wanna blow her up just yet.. shes a good little engine
Anyone got ideas ? I've also checked my boost controller pipes, all the hose clamps, everything.. i just can't seem to find it !! also, when i changed the timing i reset the ECU as an incase thing as well..
Pete
