Holy Cow - that's a long time to be getting 0 MPG. Yikes!TDot wrote:How much is excessive? Just so I'm clear, up to 4 hours at a time.
Whoa...that's a long idle time. But, and I don' know why its called an "Italian tune-up" but we used to do the same thing and called it blowing out the plugs. Some WOT used to blow the carbon build up out. We did this with our cars and bikes and it seemed to work. On todays cars I would fill up on premium gas, add some octane boost and a fuel injector cleaner. You could do FEW WOT's at a stand still, not too long, less than a minute and then take It out on the highway, even in first or second and do it again. It worked for me. Good luck.TDot wrote:For the past year I've been idling my car A LOT while doing my audio set up and doing computer programming for my front end for my computer. While doing research on how to calculate gas burn during idling I found out that idling can damage your engine. I have noticed that the car has been driving a little rougher, noticeable to me, and don't really understand why, so for now ill attribute it to excessive idling since finding this out. How much is excessive? Just so I'm clear, up to 4 hours at a time.
So my question is, although extremely general, how do I go about repairing damage caused by excessive idling if nothing is standing out? What would you look to fix or change that could have been warn or damaged due to idling? What first? And tell me the rough cost because I'm not an engine guy. Thanks.
Did not know that. Thanks for the info. Makes sense to me.svard75 wrote:It's referred to the Italian tune up because it is what Italian Ferrari drivers used to do with cars that used to be driven like an old lady to bring it back into spec.
I must agree. Excessive idle time is not good for any type of motor. Try it with a 2 cycle engine and you will see what excessive idle time will do. You then have to run them at WOT to get all the junk out of them before they can run at max power again. Our cars are the same just not as bad as a 2 cycle engines. In my OP 4 hours idle time is over the limits, unless you drive a cop car in which case they don't care or blow it out on the highway. I would recommend to the OP don't idle that long. IF you need heat buy a portable heater. Its cheaper than having to deal with all the issues other posters have made.steve_c wrote:Good responses in the previous postings regarding this issue.
During excessive idling, engine operating temps (water & oil) as well as engine oil pressure may not maximized. Rich fuel conditions wash down the cylinder bores, taking with it the oil needed to lube the piston rings. Unburned fuel merges with the oil in the crankcase (oil pan). Now you have compromized oil (thin oil from raw fuel contamination). Lower oil pressure & diluted oil work their way into & onto the various bearings, lobes, lifters, etc. causing them to wear prematurely.
The best defense (if excessive idling cannot be avoided) is frequent engine oil changes.
I agree with the other posters that todays engines are probably more resilient to the above for various reasons, but it still could be an issue. I would perform more frequent oil changes if excessive idling is the norm.
