idling at 5k after overheating
Nismo200R
Car: snowboarding,dirtbiking,
Okay the car overheated pretty bad one night. The hose clamp on the upper rad. hose came loose. I managed to get it home,and put water and coolant in it. Thenb it started to idle at 3k then i drove it for a while keeping rpms below 2k,and it idled at around there, then i got on the highway at about 80mph,and rpms were at about 4k. then when i got to neutral or push the clutch it goes up to 5. I blocked off the air regulator and it dropped. could this be my problem? also there is a really horrid smell coming from around where the air regulator is located. I cheked both the tps and the temp sensor. and when i block off the opening to the air box it doesn't affect it.
drjohn
The air reg. should be closed when the eng. is hot. It is open when cold to mix more air in with the richer mixture. If open than the idle goes higher.
Nismo200R
It was the air regulator. I took it off,and took it apart,and the little valve was stuck partially open. I hooked an ohm meter up to it,and the ohms were oscillating going up higher,like the tach was doing. Finally. Brandon
