huguetguy »
https://forums.nicoclub.com/huguetguy-u2799.html
Thu Dec 12, 2002 4:26 am
I've noticed the above symptoms since getting my car back from the shop, and will be taking it back to them, but this is my 3rd time taking it back and I'm starting to lose confidence in their ability to diagnose and correct the problem...
my sig shows all the mods done to the car, and the new engine was just swapped in a couple weeks ago. since getting it back, the car died and had to have some more head work done, and I just got it back a week ago, and it's getting worse.
upon cold start, the engine stumbles around 1.1-1.2k rpm and I have to give it some gas to stabilize it...
If I'm driving in 4th gear around 40mph and tap the throttle a little, the engine bogs down and stumbles...
last night I drove home and it was doing all this stuff, and I thought I'd check how it started while warm - so i parked it, shut if off, and tried starting it. It just turned and turned, but wouldn't fire up. I tried a few times with that and I got worried - thought I'd have to get it towed again... but this morning I came out and it started up, with the same stumbling and problems as before...
does this indicate something common - would a vacuum leak cause this sort of behavior?
keep in mind, I don't have an EGR or an AIV - they're blocked off using a kit...
Dave
