jdmnancy »
https://forums.nicoclub.com/jdmnancy-u68787.html
Thu Jul 05, 2007 5:10 pm
I HAVE A NISSAN A31 CEFIRO , STOCK AUTECH TUNE, IT RUNS REALLY GOOD, WHEN BOOSTING, BUT AT IDLE IT SHAKES, NOW WHEN I PULL OFF THE OIL CAP ENGINE STALLS, I HAVE 135 PSI COMPRESSION, AND FOR SOME REASON, IT HAS VACUUM WERE THE LIL BREATHER OUTLETS COMING FROM THE VALVE COVER TO THE OIL CATCH TANK, AND IT HAS VACUUM, I CHECK FOR VACUUM LEAKS EVRYTHING FINE, AND CHECK FOR CYLINDER LEAK DOWN TEST HAS GOOD PERCENTAGE. HAS LESS THAN 1 PSI OFF BACK PRESSURE THREW THE EXHAUST,ALSO CHECK THE VACUUM, IT READS 14 IN/VACUUM, ANYONE HAVE ANY CLUE, THANX FOR THE HELP
