idles then leans out and dies
s13_silvia_redtop
Car: 240sx
like the title says... ill start the car and it will run for about 5 seconds or so and will lean out until it dies.... its fuel pressure. spark plugs are good and i dont think its ignition. and sometimes it will run longer but if i rev it up a bit and then let off, it will go back to idle, approach 14.7 and then run all the way to 21 and die? i think it might be something with the IACV sticking open causing too much air to enter but not sure? any helps is appriciated!
MrSoutherland
Car: S13 - Sr20
Could be a number of different things. I would check for loose vaccum hoses, connections...Have you ran the ecu for codes?
s13_silvia_redtop
Car: 240sx
i have nistune installed on my computer, it will show me if i have any codes being pulled up. so i switched ECU's because i thought it might be my ECU messing up but i still have the same problem with a stock ECU. it will run ( and without any symptoms of a vaccum leak. but then randomly it will just lean way out until it dies. almost like its a fuel pressure problem but my fuel pressure gauge never looses pressure. im kinda stuck
s13_silvia_redtop
Car: 240sx
no one? do you guys think it could be the IACV sticking open allowing too much air into the intake leaning it out or would it not do that? i tried spraying carb cleaner in it but dont knwo if that did anything
