timing - cleaned maf - replaced crank sensor - throttle and iac valve, etc
turbo had gone so replaced that with a brand new one, and would idle like its got no mounts
now i've a starting and idling issue :
car will start up and run on 2k rpm thenk if any gas in given the car stalls and will not start up.
i;ve checked and its not flooding or looking spark compression is good 150 or above across on all cylinders,
checked for vacume leak but nothing to be found, i've also been told there is a brake booster pipe by the intake which if off can cause this problem, but i cant even find it anyone know where or what it looks like
any help please
ca18det s13
