LoserCard »
https://forums.nicoclub.com/losercard-u78523.html
Fri Feb 05, 2010 9:06 pm
Ok so my car is running like poop after rebuilding. Guessing it has to do with timing chain. Other topics such as mine have been covered however. I have not yet found a picture of the correct idler sprocket position.
So back to my engine... I have TDC on my main pulley (second mark from the left) and my #1 piston is in it's compression stage. My cams are perfectly aligned according to Jim Wolf diagrams. Mating marks 8 chain links away from each other...
HOWEVER... I have reason to believe my idler sprocket is off due to the fact that my engine runs smoother, but still crappy, turning the distributer clockwise and I only can turn it so far before it hits the cover (this is with the bolts off mind you).
Here is a picture of my cam and idler sprockets.
In red is the mating marks. The mating mark for the upper chain on the idler sprocket is on the bottom, somewhere near 6 o'clock.
If someone could lend their advice or show me a picture of the correct alignment of the idler sprocket, I would be very grateful.
