I need some advice on how to get my idler sprocket to line up with the sprocket bolt hole on the head. Im about a half inch low in alignment. I think when I released the new lower tensioner with no resistance it made the chain too tight for the reinstall of the sprocket. Is there a way to reload the tensioner with out taking off the timing cover? I have already taken the motor out and I would prefer not to again. How does this lower tensioner work? Spring loaded or some type of locking track? Can I force it backwards with a screw driver or is it designed not to go back in with out some other release button pressed? Also this is a replacement timing kit and the new idler sprocket does not have any holes in it to use a screw driver to pry it up. Please need help! Its a 97 nissan altima ka24de.
Nick
