Idler Sprocket Bolt Question
SLAYTER
Car: Pink S13 Silvia
This may be seen as a really dumb question but i'm asking anyways.
(Yes I know I can heli-coil out the thread itself, and use a heli-coil, but i'm asking this to see if I can avoid such)
Has anyone had problems getting the idler sprocket bolt back on? The problem I had was th bolt will thread in by itself all the way and torque down. The moment I put the sprocket in place with washer it goes all the way to hand tight / 20ftlbs and then spins out over and over. I remove the washer, and the problem goes away, so essentially I suspect just a few threads are messed up inside but i'm not sure...
My main question, can I just say F it with the bolt hand tight and finish attaching the cam chain and sprockets and use that chain to kind of "brace" the idler sprocket, once the timing covers back on that bolt can not walk itself out at all, and the cam chain would technically brace it to the motor would it not?
Thanks for the help... Worse case scenario i'll go get a heli-coil....
SLAYTER
Nevermind the question, i'm just going to Heli-Coil it and do it right.
tramp_drift240
Car: 1992 240sx SE Coupe
DUDE did you end up helicoiling it?
if you got the kit for it, PLEASE let me know. ive got the same problem right now.
SLAYTER
Yes I ended up doing a Heli.
tramp_drift240
would you happen to still have the tap, tool, and a single insert i could get off of you?
SLAYTER
Neg I did it at my shop.
tramp_drift240
super weak.
SLAYTER
Call a machine shop if you've got the head off, its not something hard to do. Would cost you maybe $25-40 to have a machine shop put a heli in.
Anything more then that and they are ripping you off.
tramp_drift240
well i pulled my head back off and called a machine shop yesterday, 35 bucks and a day later ive got my head back with fresh threads.
i guess im too DIY-minded to think about calling a machine shop first.
thanks for the help
