Idler pullies?? Are
RT22
Car: 1991 nissan hardbody
the upper and lower the same part number? getting conflicting info locally. 91 ka24e, replacing the one on top for power steering and lower on ac. Went to courtesy online and shows one with a different letter at the end of part number but number the same. Is offset different? Need to know before tearing it down and not having a way to parts store to replace if different. On the truck they look the same just want to be 100% sure, local parts say SAME. Thanks for any help.
moneymike
Car: 1991 nissan d21 hardbody
i know the are the same
if its a different part number it was be for the pully that is ribbed instead of v
the ka i got from a 240 had all ribbed pullies i had to swap out mine and put the v pullies back on or else bye bye belts
RT22
Thanks
moneymike
no problem im not 100% sure thats what the difference but it could be
RT22
THEY are big time different the top one on Power Steering is 18 bucks and smaller. Bottom AC idler is bigger and has removable bearing NOT even close to the same, just some info I just learned first hand LOL
