rhatmonkey »
https://forums.nicoclub.com/rhatmonkey-u93322.html
Thu Jan 08, 2009 10:50 am
brief history on my 240sx vert. i bought it about a year ago and had the KA and auto transmission swapped for an SR RedTop w/5-speed about 4 months ago, everything has been running great. even had my ac from the ka moved to the sr (cause let's face it, summer's too hot sometimes).
so about a week ago my car started making this loud whining noise so i spent a few minutes investigating. i found that if i removed all the tension from the belt (it connects my crank to the ac) by loosening the idler pulley the noise stopped and all i could hear was her purr but if i tightened the idler pulley back on the belt to give it tension the sound came back. now i've read all over here that when it does that it's time to replace the pulley,.. the only problem is i can't find it anywhere.
[ i call it an idler pulley cause all the manual's i've seen for the sentra se-r show the name, just no part number ]
i've read i can just order one for a '92 sentra se-r (2.0L sr20det) but nissan swears up and down you can't get an idler pulley for it and that the belt should go around the power steering pump, ac, adn crank.. the only pulley's i can find fit a '00+ sentra 1.6L.
my question is this: where the hell can i find one of those pulley's and can i use the ones for a 1.6?
thanks in advance.
