Idleing problem
mibubio
Car: 1993 Nissan 240sx
I am new to nico i just bought a 240 with some stuff done to it, and i have a problem with the idleing when i start the car it with start and idles really rough and it will stall but it drives fine, and there is no problems after that, but when i come to a stop sign or light and have to stop it will also idle really rough does anyone have any ideas
ChuckNC
Car: 1992 240sx hatchback
Use the SEARCH link at the top of this page, even if you have to try a few times with different word combinations to get the results you are looking for. There have been many, many, many postings on this subject. It could be one, or more, of several different things, but I would start out by running some Seafoam through the intake using the vacuum line and cleaning your MAF sensor. All of this information can be found by using the before mentioned SEARCH feature. Also, make sure the harness on your MAF is not loose.
edit: and it would help to mention if your car is stock or not
