Duce40sx »
https://forums.nicoclub.com/duce40sx-u62837.html
Sun Apr 29, 2007 9:52 pm
Steve.
I just had the same problem you're experiencing. I took the initiative to fix it.
Adjust your IDLE SPEED.
Like your car, My car WAS WAS WAS IDLING at 7,00 to 750 rpm. When I popped it into NEUTRAL, the car's Idle drops to almost ZERO.So, I used COMMON sense. By Raising the IDLE Higher that FACTORY.FACTORY IDLE = 700 RPM (+PLUS OR - MINUS 50)WHICH MEANS, 650 RPM TO 750 RPM.
1. I drove the car around the block a few times. (Getting it nice and warmed up)
2. Turn off the CAR
3. Disconnect the TPS (sensor) which is zipped tied onto the Rubber PCV TUBE. (PVC TUBE =The one that goes from the PVC vavle(on the valve cover to the intake)
4. Start the car.
5. Rev the ENGINE from two Thousand RPM to 4,000 rpm.
6. Get a Phillips screw driver, TURN THE IDLE ADJUSTMENT SCREW COUNTER CLOCKWISE, (which opens up the AIR passage and giving you a HIGHER IDLE)
7. Rev the ENGINE again, and set the New IDLE to 1,100 RPM.
8. TURN OFF THE car.
9. Plug back the TPS (Throttle Position SENSOR)...
10. YOU'RE DONE!
11. Now that you're done, everytime you drive, the Idle will sit at less than 1,100rpm ....It will surely fall to 900. and you will not experiece the "Idle DROP".
12. Once you solve that Idle drop, you can go back and Lower the Idle a TAD bit.
X: Since we know that our IDLE DROPS VERY LOW and THE CAR TENDS TO SHAKES AND EVENTUALLY STALL.
XX: WE SET THE IDLE Higher that OEM standards to Ensure that If the IDLE does Decrease, we have "safe" tolerance. THUS it will not die.
XXX. I did this, and my car runs SUPER! MY car idles at 850 - 900 RPM
I am DEAD Serious. my car HAS 167,540 MILES. (1993 240sx COUPE, Base Model)
And It will smoke your car STEVE, I know how to TUNE my car. If you do not trust my Expertize, I suggest you go Pay a mechanic man.
GO download a NIssan 240sx FSM. Factory Service Manual.
It's all over the internet. DOWNload it.
I am helping you OUT man, If you don't want to Diagnose this problem. I care less. I am wasting my time to HELP YOU.
Duce, Peace. Good luck. Try it and you can Thank me later.
