CanuckQx4 »
https://forums.nicoclub.com/canuckqx4-u160090.html
Sun Mar 11, 2012 7:03 pm
Well Town. I got it running perfect. But not by any method of the FSM lol
I got fed up with failed attempts so I thought, since I can see realtime that my ultragauge is displaying 44% throttle, why not just loosen the TPS nuts and adjust it slightly til it said 0
Sure enough, worked great, idled perfect, barely jumped up in rpm when I started it. Idled @ 775rpm
BUT, I decided to check with the feeler gauges if the TPS position was still in spec, it wasnt, but it was barely out. But it was only out the ammount from where I originally adjusted it from. So I guess I just tweaked it back to where it was before.
So do I leave it and forget EVERYTHING was done wrong but it works. Or do I pick at it and learn more curse words??
Thanks for your help again bud
