chicos240 »
https://forums.nicoclub.com/chicos240-u20799.html
Wed Feb 07, 2007 3:24 pm
I had the same issues, here is what i did.1) checked all vacuum leaks and found one2) Cleaned the MAF connections3) Unplugged my TPS4) Undid the throttle cable5) Took out the Idle screw and cleaned the oring and shot some carb cleaner in the IACV valve.6) Put the idle screw in all the way and came out 3 turns7) started car and adjusted idle screw untill it got to about 900.8)Turn off car...Re hooked my throttle cable to make sure there was no pull on it.9)Turn on car and make sure its still at 900...turn off car10)Hook up TPS and turn car back on voila!
