idle
fyneyoungstunna
Car: nissan s12...more to come
how do you adjust the idle from the throttle bodies?
mrmoose
Car: 91 300zxtt
You are not supposed to because the tps voltage will be off. But just loosen the cable bracket nuts and do it that way if you want to use the cable...
fyneyoungstunna
Let me elaborate I took the aic or whatever off (back of theplenum drivers side) so now I need to adjust idle. I know what ppl are gonna say about deleting it but try to leave that out of this thread.
mrmoose
Car: 91 300zxtt
Ok drill One, small hole in each of the tb plates. Very small holes, you only get one shot and can always make them bigger to raise the idle.
fyneyoungstunna
^ really? that did cross my mind at one point
