InitialForce »
https://forums.nicoclub.com/initialforce-u195785.html
Sun Dec 25, 2011 7:45 pm
If you have access to another Mass Air Flow Sensor try that. I had similar problems. Basically my MAF would put out the right range of voltage so my ECU never thought anything was wrong with it and it kept trying to open and close the IAC as if it was trying to get it unstuck causing my car to sometimes idle as high as 3k rpm... and every once in a while the car would just die while I got my foot on the cluth. The MAF NEVER once threw a code but as soon as I replace mine with a new unit all my problems disappeared... matter of fact my ECU threw Fuel Temp Sensor, IAC, Random misfire codes but never a MAF code...
So anyways, the MAF could be giving the right range of signal so the ECU doesn't think anything is wrong with it but telling the ECU that less air is being sucked in then actually is creating a lean condition and a high idle in return.
Off course it could also be a vacuum leak somewhere creating a lean condition. Check for any cracks in the PVC hoses, Idle Air hoses and all vacuum hoses. If you took the idle air balance tube off at some point there is a good chance you damaged the O rings in the process
