idle?
osolorb
Car: 1992 240sx fastback rb20det
i have an rb20det in my s13. is there an iac (idle air control). i played with the idle for about an hour the other night, got it set to 750-800 rpms and the next day it was idleing at 2800 rpms. what can i do to set the idle. thanx mike
daveh93s13
Car: 96 240sx se coupe
i believe the iac is on the side of the throttle body closest to the firewall. i think it has a brownish red connector to it. but to be totally honest, im not positive. i have a rb20det in my s14 and i have a high idle, my s14 tach dosnt work with the rb20 motor, so i dont know what im idling at. id guess its around 1500 rpms. i got the car with the motor installed already but the kid said it wasnt finished yet ( the swap), that the coolant temp sensor wasnt hooked up etc.
what causes a hard cold start and a high idle? even when warm it has a high idle.
ka24eracer
Car: 180sx...
Yes you're right , but its called AAC ( auxiliary air control ) and you can try a know good ka24de AAC , its supposed to fit on the rb20.
S13 240SX
Car: 93 Mazda Miata
omg guys my rb20 does the same thing.
been months and still no fix.
S13 240SX
Car: 93 Mazda Miata
ka24eracer wrote:Yes you're right , but its called AAC ( auxiliary air control ) and you can try a know good ka24de AAC , its supposed to fit on the rb20.
yes it does fit but u have to get the right ka24de aac cuz the came out with two diffterent types.
get one off an s14.
ka24eracer
Car: 180sx...
Yeah the way to know is by the connector color also , tell me if im wrong but I think it got the be purple
S13 240SX
Car: 93 Mazda Miata
yep thats right.. the one with the purple and brown ka one..
