shiro_neko »
https://forums.nicoclub.com/shiro-neko-u152359.html
Sat May 01, 2010 10:36 am
sounds like an exhaust leak. check your exhaust gasket.
for the hesitation, try removing vacuum hose from fuel pressure regulator and try to drive. improves, check fuel pressure.
remove exhaust gas sensor harness and try to drive. improves, replace sensor. also check your ignition wires and plugs. and dont forget to check your timing.
