Idle Studder...
All things Altima Coupe.
08AltimaCoupe
Hey guys,
I have an odd problem want to see if anyone else runs into the same problem.... I have a 2008 2.5 Coupe, and after about 15 to 20 minutes of driving and I come to a stop the idle will drop low enough where it feels like the car is going to stall but then kicks back up immediately... Not quite sure why its doing that its never done it before i kinda though it might have something to do with my K&N typhoon intake but its been on for about 6 months now and no prior problems.... so I'm not quite sure what this could be if you guys have any ideas I would love to hear em.. Dealer wont do s*it for me saying they cant help me unless they see it do it and of course i cant get it to do it in front of them... right now im ready to choke the dealership...
Thanks in advance,Josh
Chiefster
Car: 09 Altima Coupe 2.5 Super Black
DO you have subs???
RaiderKID
Car: 2.5 Percision Grey Altima Coupe
youre not the only one i also have the k&n and once in a while it seems to do the same as yours but i do not think its the intake?
Can it be?
08AltimaCoupe
subs as in jl audio 12's i do now... but those were put in about a week ago... its done it before they were put in as well but your thoughts are welcome...
DarkKnight22
I've noticed it on mine too. I have 15k miles 08 2.5
I have a stock intake with stock filter.
Don't know where this applies but I do have 2 Alpine Type R 10's?
Chiefster
Oh ok...cuz i did have a camry 2003 camry as my first car and i put subs and it did the same thing..especially wen my music was blasting,air conditioner was on,and lights were on... i did some research and it seemed to point towards the alternator,but i could be wrong.
08AltimaCoupe
Bump to try and get some ideas....
2010alticoupe
Car: 2010 CrimsonBlack
coupe
Does anyone know about this? Today when I got home, I noticed that it sound like my car wanted to shut off or stall. I looked at the rpms and it was at about 750rpms. That's while parked.
boystar22
Car: 2008 Nissan Altima Coupe 2.5S
Mine has been doing this as well lately and I also have a K&N Typhoon. I have a ground wire kit, but no audio upgrades.
SneakyFish
Car: 2008 Altima Coupe 3.5SE CVT
ive been having the same issue. Cant seem to reproduce it though. my mechanic said it could be that i got the throttle body dirty?
AlexN09
Car: 2011 Nissan Altima Coupe S 2.5
My altima only has 4000 miles on it and it's always had a shaky idle if I drive for a while and then put it in park and sit. The idle drops really low and the whole car shakes
Coupe12
Car: Nissan altima coupe. 2008, 2.5S
Mine shakes sometimes at stoplights.... No aftermarket air intake or audio
Jman0711
It could be your MAF sensor. Not saying it is but it is a possibility. Try removing it carefully and cleaning it with electronic cleaner, autozone etc. has it.
And the only reason that one person was mentioning subs is because if you have subs and their up loud producing bass it will draw more power from the alternator causing the rpm's to go down,/lights dimming etc. But that will only happen if you have your radio loud/bass hitting hard.
IBCoupe
Car: '08 Nissan Altima Coupe 3.5SE
'19 Infiniti QX50 FWD
'17 BMW 330e iPerformance
Your cone filter is probably attached to the intake tubing by a worm drive clamp. Tighten it with a ratchet, not just a screwdriver. You said it's been on there for six months, and chances are you've hit quite a few bumps since then. A loose air filter on an aftermarket intake can cause at least some of the symptoms described in this thread.
I had a funky idle and a SES light. It finally went away when my cone filter fell off and into my K&N's heat shield. If it's not on tight enough, that can cause a bad seal and inconsistent airflow, which can throw off your MAF. Before you go messing with the MAF sensor, ensure that everything ahead of the MAF isn't the culprit.
In fact, your intake tubing itself is probably attached to the throttle body by another worm drive clamp. Make sure that's on there good and tight, too.
