It's idling a lot fast. Was it idling at 1100 rpm before you removed the plenum or is the high idle something new? What was the pre-plenum-removal idle?rabsusa wrote:.....Mine is currently idling at 1100 rpm, it feels a little fast - it jerks when put in gear - recently removed plenum to do injectors....
Are you referring to the throttle cables attached to the bracket above the EGR? Did you clean the EGR valve, AAC valve and TB while the plenum was off? Use new gaskets on these 3 components when putting it back together?rabsusa wrote:.....however i did 'mark' retaining 14 mm nuts with tipex and only released one side of each connection - was aware of inadvertantly making changes when taking it apart......
If there's any doubt as to correct adjustment of the throttle cables you should check the TPS sensor voltage. If it's way off from spec (0.44v) you may have to adjust the sensor, or the cable slack, or both. If the TPS voltage is in range then an idle adjustment to the 650-750 range using the AAC valve is in order. I believe it's 3 1/2 turns out from closed.
All of this is easy with a consult cable plugged into your laptop since all the values are real time on one screen. Going to Cocoa Beach anytime soon? I know a guy.....
