Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Nov 04, 2003 12:59 pm
Fast idle warm up speed is purely a function of coolant temperature [the hot wax automatic slight opening of the throttle plate] and the added IAC duty cycle to fine tune the speed.
Fuel pressure has little to do with it as long as you have the 34 psi at idle minimum.....................clamping off the return line [a severe test that shouldn't be done more than a few seconds ---really stresses the pump] [raises the 34 psi to 60- 65-70 psi.............increasing the fuel flow by 38% but the ecu just decreases the injector open time to reduce the flow [if the O2 react] otherwise you just get an extremely rich idle mixture and some black smoke till the cats heat up enough to burn this extra fuel.
Doubt the fuel pump caused the change if there was a change, just cooler temperatures after summer.
