Idle's Low problem fixed
GrEy240SX
If you guys remember i had a problem that made my car shake and idle low. all i did was clean and clear out the throttle body and it runs fine now. so if anybody has this problem you should try this...well later.
GrEy240SX
and i should be posting pics of my car soon!
nissanrcer240
Car: 90 Nissan 240SX SR20DET
what did you use to clean it out, my car does the same thing...what exactly did you do, just take off the intake hose from the throttle body and just spray it with what ever you used?? did you have to wipe it out or anything?
GrEy240SX
i think it was some carb cleaner. just sprayed in on the "gunk" then reved the engine a bit. then wiped out the excess.
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
ooh, i need to clean my throttle body i think, when i rev it up to like 4k, and then let it come down all the way off throttle...it starts to bog and kinad stumble at like 2k rpms...it's weird and unsettling
maybe it's the TB...possibly?
