Ok so this is a hatchback 93 stock with a few here and there as far as air intake msd no mayor things. I just had new headers installed, Then the EGR tube top one installed a new one as well. I replaced new injectors, I did a compression check and is like new 179 on all 4 cylinders so is not a blown gasket issue or seal. Also a fuel pressure check was done and it holds at 36sh then after a while down to 10 which is normal. It sounds like there's an air leak in between the engine and the firewall but I check and everything looks good. Today I cleaned my maf also the throttle intake and ordered a new 02 sensor which I will start after installing and see how it goes. It also has brand new spark Plugs. weird because it starts good and I took it for a little spin and it runs good is just that it idles a little bit then it grabs strong and goes. I will check my injectors again for any leak, I will also check if I'm getting any code in the ECU. These cars a stubborn for real!
I will not mess around with the IAVC is very hard to work around that area but is something around there if it comes to it I rather have someone do it and get a new one if thats the case..
