Problems started after my dad replaced a dead battery car ran great before, sudden problem. Realising now that may have caused the car to forget throttle.. The car suddenly died while driving twice but would restart and drive normally. Then some idling issues, they took it to a mechanic who "cleaned" the throttle body he said if that diddnt do it then replace the tb lol. the car was throwing p0159 and p1167 (02 sensor slow response and max volt monitoring.) After back from mechanic the car would idle sporadically up and down, changing when in gear.
I noticed right away the iacv was leaking pretty bad onto a coil, whole area was soaked. Must have been a lot of coolant getting into the throttle body. I replaced the iacv right away then after some research realized it can fry the ecu one will short out the other when bad.. cleaned the throttle body properly and replaced gasket. Back side of tb was quite dirty.
After starting and running nice for a few moments the idle dropped then died, wouldn't start without manually giving it throttle. Pulled a code for low idle, after waiting for my new pos scanner. It only picked up the max voltage 02 code.cleared codes. Tried various throttle relearn procedures and nothing seems to stick. Tried what's in the manual at page ec-72 and after trying multiple times I found this page https://www.altimaforums.net/threads/id ... -way.3398/ wich helped. Got the check engine light to start blinking finally as one of the last steps but it is supposed to stay steady illuminated after 20s. Just kept blinking. The idle would seem to learn for one start up then forget for the next, or if I revved engine a few times it would drop to 250-400 rpm stutter or die.
Took for a couple test drives diddnt help though runs ok while driving after pedal position realearn just too low idle trys to die at a stop. Cel still off.
I want to test and replace pcv and plugs but have to remove tb and intake manifold wtf?! I want to tune it up. Going to clean maf tomorrow and see if it helps.
Would it fail to learn if the maf was bad or 02 sensor was bad? Time to check ecu for fried chip? Could the ecu be fried at this point? It runs great right after learning throttle then forgets..
Was hoping not to replace the 02 sensors but noticed today one was covered in oil.. oil leak seems to be coming from oil cooler and running all the way down
