krash »
https://forums.nicoclub.com/krash-u27755.html
Tue Jun 30, 2009 8:39 am
Alright so I just swapped the motor in my 93' 240. Same exact engine, s13 ka24de ran fine before it was in my car. So here's the deal. I started it up and it idled okay for maybe 10 seconds and then it slowly bogged down. Figured it was a vacuum leak, check all the hoses I could find and they all looked fine. I searched here and I saw some people saying to unplug the MAF and see what happens. If the car runs fine with the MAF unplugged then apparently the MAF is bad. So I tried that, and the car ran normally after I unplugged the MAF. So I quickly swapped the MAF from another 240 just to make sure that was the problem. Plugged in that MAF and I had the same problem as before. Unplugged it, car runs normal.
Any ideas?
Edit: I'm an idiot sometimes. Mods if you could move this to the online mechanic section that would be great.
