idle problems.
mofeel
Car: red 1990 Nissan 300zx n/a 2+2 5spd. sold
1993 nissan 240sx fastback 5spd. sold
2000 gc8 Impreza 2.5rs coupe. daily
1974 260z. project
yo guys im new to 240s n i got a trade offer for this 93 model hb wit 163k on it, the guy replaced the tps and it runs fine cold n when u drive it for a long time n let it sit for 30 min it dnt want to start and it doesnt ideal right u have to crank it for a while then it will start. ik its not a good explanation but ive been wanting a 240 forever and im interested but idk if i should. it also needs a valve cover gasket cuz it leaks bout half a quart a month. could it be he needs to adjust the tps?
FlipCoupe
Car: 1991 240sx Hatch
Hey guys, I'm new to 240's and I got a trade offer for a 93 hatchback with 163k miles on it. The guy replaced the TPS and it runs fine cold, but when you drive it around and let it sit for 30mins it doesn't want to start and it doesn't idle right. You have to crank it for awhile for it to start. I know its not a good explanation but I've been wanting a 240 forever and I'm interested in the trade but I don't know if I should. It also needs a valve cover gasket because it leaks about half a quart a month. Any help? Could it be that the TPS needs to be adjusted?
I don't have an answer for your problem but poorly typed paragraphs really bug me.
mofeel
1974 260z. project
well srry for the poorly typed paragraph. i jus need sum help on wat it could be
costa_rican13
Car: 1993 s13 coupe
unplug the tps, raise the idle to 1500 viA THE IACV screw then plug the tps back in call it a day.
mofeel
1974 260z. project
thanks ill tell the guy to try that n see if it works.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Clean the IAC too, check vacuum lines, adjust TPS
Morph
Car: 91 Sr Powered Coupe
FlipCoupe wrote:Hey guys, I'm new to 240's and I got a trade offer for a 93 hatchback with 163k miles on it. The guy replaced the TPS and it runs fine cold, but when you drive it around and let it sit for 30mins it doesn't want to start and it doesn't idle right. You have to crank it for awhile for it to start. I know its not a good explanation but I've been wanting a 240 forever and I'm interested in the trade but I don't know if I should. It also needs a valve cover gasket because it leaks about half a quart a month. Any help? Could it be that the TPS needs to be adjusted?
If you going to post to be a d!ck dont post at all. That crap doesnt impress anyone.
Op as Out said check the IVAC. If you search the forums there should be a few write ups on how to clean it with it still attached to the car. Also check the MAFS make sure its clean and it wouldnt hurt to get some Electrical cleaner and run it throught it. I had an idle and throttle issue that was cleared up by doing those two things.
