This is one of the best writeups for removing the plenum:
zer...tures.
And there are many things that can cause Idle problems:
http://q45.org/roughidle.html.
And to add check the Injectors when they are cold (Car sitting for a day) and hot (After fully warmed up and driven).
Check for any vacuum leaks.
And check your spark plugs.
So to sum up:Injectors/Fuel pumpAir (MAF, AAC Valve, Vacuum leaks)Ignition (Spark plugs) (NEVER THE COIL PACKS AS THEY ARE BUILLIT PROOF on the G50 (90-96 Q45's) that can't be said for the FGY33 (97-01 Q45's)
