Warped »
https://forums.nicoclub.com/warped-u5976.html
Sun Apr 05, 2009 5:31 pm
Vehicle is a 1993 240sx coupe w/ a ka24de and a 5speed transmission
I cleaned the maf with some cleaner we have hear at work
i can pull the plug to the maf and the car will idle fine.with the maf connected the car will fluctuate at idle from 400rpm up to about 1300rpm and some times die.but everywhere above 2000rpm its smooth
I have not cleaned the iac valve yet but i just installed a different intake main i got from someone on the boards off of a motor that was pulled.all lines are plugged except the fuel pressure regulator and the iac. their is no egr on the vehicle also.pcv system is vented to atmosphere with a filter and the intake mani has the ports capped.
Also in the intake piping there is a big hose that supplys the air for the iac valve their is also a smaller port on the intake piping. where should that connect too?I have it capped right now.ids added
Modified by Warped at 12:36 AM 4/6/2009
