dogred »
https://forums.nicoclub.com/dogred-u134060.html
Thu Jan 13, 2011 8:35 pm
I know I am going to get a little bit flamed for this. Under a severe time crunch and money strapped.
The back history.
I could not get the timing to dial in while using a gun. Lots of pinging while on the gas in 4th and 5th gear, especially going up inclines. The closest i could get it was 10 deg btdc.
What the mech told me
The silver link on the chain was meeting up with the number one on the cam gear. He replaced the cam gear, chain, guides, and tensioner. He said he left the crank gear and oil thrower on, but the thrower looked a little bit chewed up.
The current situation
Now it runs like crap at idle, the engine vibrates like crazy, the idle is at 1000 rpm. If I adjust the carb screw to lower the idle speed it shakes more violently. Below 1500 rpm it sounds like a Subaru Impreza.
Above 1500 rpm it is awsome. Do not have access to a timing gun as of now.
All the vaccum lines appear to be hooked up correct and tight.
Any ideas would help out.
Which coil is the intake coil?
